what authentication mechanism does WLC controller uses ?
Hi Team ,
To login to WLC controller via GUI - we would like to know what authentication mechanism does it use to authenticate local users(AD credentials)
Regards ,
CK
Rasika Nayanajith
can you clarify your question?
It uses Local Authentication as you configured local username on WLC itself
Rasika
@Rasika Nayanajith Sorry no …It uses AD credentials…
It may be using TACACS based authentication, have a look below & see a similar config on your WLC
https://mrncciew.com/2013/04/26/wlc-admin-access-via-tacacs/
Rasika
*** Pls rate all useful responses ***
Hi @Rasika Nayanajith
I did not find any configuration under TACACs , But could see under RADIUS , So does this mean we use RADIUS for authentication?
