Cisco C9105 AXI-E Setup
I need help in setup Cisco C9105-AXI-E as Cisco Embedded Wireless Controller,
the total of AP I have is 6, and i need to setup for at least 2 SSID in two deferent VLANs. unfortunately i am not able to find the correct document or article for that.
thank you.
9 Replies 9
Mark Elsen
 - If you talk about basic configuring it's no different from 9800-XE , you may find this video useful and or applicable :
           https://www.youtube.com/watch?v=5FpYS_rphik
           https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/videos/Basic-Configuration-of-Cisco-Catalyst-9800-Series-Wireless-Controller.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
This Video recording is the second in the series of the Cisco Catalyst 9800 series configuration based on the Cisco Cloud platform. ThisBasic WLAN Setup recordings will explain how to use "Basic setup" on the Cat9800 controller. This Video recording will be followed up by four additional episodes
Rich R
https://www.cisco.com/c/en/us/support/docs/wireless/embedded-wireless-controller-on-catalyst-access-points/215303-embedded-wireless-controller-conversion.html
https://www.cisco.com/c/en/us/td/docs/wireless/controller/ewc/17-6/config-guide/ewc_cg_17_6.html
https://www.cisco.com/c/en/us/support/wireless/embedded-wireless-controller-catalyst-access-points/series.html#~tab-documents
Please click Helpful if this post helped you and Accept as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
Thank you for the reply, actually i have two issues, first one that i need to configure two SSIDs into different VLANs and i am not able to achieve this setup! As i saw in one of the documents that has to be only with flex. If any one coukd guide for this setup.
Second one, when ever i setup the AP the ciscoMac SSID for the day0 is not going even when i save the configuration?? Also when i reload the AP the new SSID i created will stop broadcasting but i can see it configured in the AP.
I really appreciate your help with achieve this setup.
Start by only configuring the "master" AP before adding the others to the network, to ensure you actually configure the correct one. Once you are done with the master and everything is working, add the others to the network and they should automatically join the master and get the master configuration after some minutes. Not sure if you need to "adopt" them on EWC though.
Actually this is what i am doing, i started with one only. I did not connect the other. Right now i am trying to get the vlan setup and get each ssid in correct vlan.
Please note, for this you will need a trunk port on each switchport where you connect an AP to. The native vlan should be set to the one you have configured as "untagged", usually the management interface.
Yes, I have configured the port where the Ap has connected as trunk also with the native VLAN for the management VLAN where I give the interface IP.
I am following the documents and still trying, but it is still not working. there must be something missing in what I'm doing and it is not mentioned in the documents.
the setup
This shouldn’t be a problem at all. Could you share me please a screenshot of your networking settings and also the SSID configuration?
Which software release are you running? Who knows, maybe you are hitting some weird bug.
