What is the default web-auth required timeout period?
hokokshun
As according to the cisco config example. (http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008067489f.shtml),
it says:
If clients are in Webauth_Reqd state, no matter if they are active or idle, the clients will get de-authenticated after a
web-auth required timeout period (for example, 300 seconds and this time is non-user configurable). All traffic from the client (allowed via Pre-Auth ACL) will be disrupted. If the client associates again, it will move back to the Webauth_Reqd state. If clients are in Webauth_Reqd state, no matter if they are active or idle, the clients will get de-authenticated after a web-auth required timeout period (for example, 300 seconds and this time is non-user configurable). All traffic from the client (allowed via Pre-Auth ACL) will be disrupted. If the client associates again, it will move back to the Webauth_Reqd state.
What is the default web-auth required timeout period stated in the example?
Many thanks.
2 Accepted Solutions
pcroak
Wireless clients that do not complete the web-authentication process will be deauthenticated after a 5 minute period. This timer cannot be configured.
The clients will likely associate right away again, but this behavior will continue until web-authentication is passed.
-Pat
Salil Prabhu
Yes it is 300 seconds and non-configurable to prevent DOS by depleting IP address on Guest wlan/vlan. There is an enhancement request filed esp. for your situation with Pre-auth ACL.
CSCtj32812    DHCP Option to mitigate the problem of guest client rejoining network
Thanks.Salil
CSCtj32812    DHCP Option to mitigate the problem of guest client rejoining network CSCtj32812    DHCP Option to mitigate the problem of guest client rejoining network
6 Replies 6
pcroak
-Pat
Salil Prabhu
Thanks.Salil
Thanks guys for explaining to me. it has been a great help.
Salil, may i ask what is CSCtj32812 which is in your reply? And what do you mean by DHCP Option to lessen the problem?
CSCtj32812, is an enhancement bug filed on the WLC to mitigate the problem you are facing.
You can look more details by going over the following link.
Bugtoolkit : http://tools.cisco.com/Support/BugToolKit/action.do?hdnAction=searchBugs
The idea what they are trying to use is move the client to RUN state upon utilizing DHCP options send by DHCP server..
Thanks..Salil
Thanks Salil...
Thanks . Between if you think this question helped answer you query can you mark this questions as answered so others can benefit when they search.Ofcourse, this also gives credit to folks who responded.
Thanks..Salil
