What is the max. number of SSIDs (run simultaneously with different security profiles) on the new 9120?
g.jonas
I Have to verify that the WAP (9120) supports at least 8 SSIDs with different security profiles simultaneously. Is there any document where I can find this information?
You should try and ideally keep the number of SSIDs on a channel down to 2-3 SSIDs and look at using AAA override or iPSK to seperate the different users into different segments.
There is a good reference on adding SSIDs can have effect on WIFI performance located here.
http://www.revolutionwifi.net/revolutionwifi/p/ssid-overhead-calculator.html
As Leo said the max that you can apply to an AP technically is 16 but I would not recommend this
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Leo Laohoo
Up to 16 SSID but it is not recommended best practice.
