what is the meaning of yellow color blinking for 3g/4g led in cisco 819 4g router
tarekfattal1
what is the meaning of yellow blinking for 3g/4g led in cisco 819 4g router?
5 Replies 5
mohanak
LED
Color
Description
SYS
Yellow
FPGA download is complete.
Green (blinking)
ROMMON is operational.
Green (solid)
Cisco IOS is operational.
Green (four blinks during bootup)
Reset button has been pushed during the bootup.
Off
After powering up, when FPGA is being downloaded (in ROMMON).
ACT
Green
Network activity on FE switch ports, GE WAN port, 3G cellular interface, and serial interfaces.
Off
No network connectivity.
WWAN
Green
Module is powered on and connected, but is not transmitting or receiving.
Green (slow blinking)
Module is powered on and searching for connection.
Green (fast blinking)
Module is transmitting or receiving.
Off
Module is not powered.
GPS - EHWIC
Green (solid)
GPS coordinates are obtained.
Off
GPS is disabled, GPS is enabled without GPS mode and NMEA configuration, or GPS is acquiring.
GPS - 819 ISR
Green (solid)
Green (blinking)
GPS is acquiring.
Off
GPS is disabled or GPS is enabled without GPS mode and NMEA configuration.
RSSI
Green (solid)
Signal > -60 dBm
Very strong signal
Green (three blinks and then a long pause)
Signal <= -60 to 74 dBm
Strong signal
Green (two blinks and then a long pause)
Signal <= -75 to 89 dBm
Fair signal
Green (one blink and then a long pause)
Signal <= -90 to 109 dBm
Marginal signal
Off
Signal <= -110 dBm
Unusable signal
SIM
Green / Yellow (one green blink followed by two yellow blinks)
SIM in slot 0 is active, SIM in slot 1 is not.
Yellow / Green (one yellow blink followed by two green blinks)
SIM in slot 1 is active, SIM in slot 0 is not.
Off / Green (two green blinks and then a pause)
No SIM in slot 0, SIM present in slot 1.
Green / Off (slow single green blink and then a pause)
SIM present in slot 0, no SIM in slot 1.
Off / Off
No SIM present in either slots.
3G/4G
Green (one blink and then a pause)
For 1xRTT, EGPRS, or GPRS service.
Green (two blinks and then a pause)
For EVDO, EVDO/1xRTT, or UMTS service.
Green (three blinks and then a pause)
For EVDO/1xRTT RevA, HSPA, or HSUPA/HSDPA service.
Green (four blinks and then a pause)
For HSPA+ service.
Green (Solid)
For 4G/LTE service.
Off
No service.
thanks dear mohanak,
I have this table but at the end you find 3g/4g led (only green color is mentioned)
what about orange or yellow blinking?
Did you ever find an answer to this. We have one unit doing the same.
Seems to be working ok, but would like to know what the orange led is for as all documentation says green.
same issue, any news about the reason of the yellow blinking led?
cpueringer
anything new? i have the same issue
