what need I do before I install required patch?
closey
After I installed CD_one_2_Edition,there is a warning said:''This system does not have patch 105529-07 installed.This patch is required for running Sybase on Solaris 2.6."
I want to know before I installed this patch,what need I do with the CiscoWorks2000 software,and after installed this patch,what need I do to restart the CiscoWorks2000 software.Thanks very much!
rmushtaq
Level 11
Level 11
Upgrade to CD-One 4th Edition bundle, it has several major bug fixes and new device support. As for the above message about the Solaris patch, if this is a warning message, then you can ignore it.
