What to replace 1242 mesh access points with?
willsmith1701
We recently migrated off our centralized wireless hardware to new converged 5760/3850/3702 hardware.  Our mesh access points were somehow
overlooked in the upgrade. They are model 1242's, mounted inside, but connected to outdoor antennas mounted outside to provide outdoor coverage. From the look of the outdoor antennas, they might be model ANT2506.  We are looking for a replacement path from mesh 1242 access points still connected to a legacy 4404 controller. As the IOS/XE code does not support mesh, it seems we probably have to buy a 2504 controller running AireOS to support mesh.  The access point and antenna model migration path from the 1242/ANT2506 seems less clear.
Two of the access points are used as a backhaul - they have outdoor antennas lined up with each other from across a playing field. The distance between the two backhaul antennas is approximately 650 feet.   The other two do not face each other and are mounted in two different locations, and have outdoor antennas overlooking two different playing fields.
What new mesh access point and outdoor antenna model combinations could be used to replace the old ones?
Please ask questions if you need more information to make a suggestion.
willsmith1701
I realize this  may be more of a pre sales question then a technical question, but if anyone has any suggestions I would like to hear them.
Also, to add to the previous configuration information, there are 5 access points in total, 3 in bridge mode and two in local mode.  The bridge mode AP's are configured with universal client access enabled, so they are also serving clients over the backhaul radios.
Moin Ilyas
Level 4
Level 4
Please refer to the following link:
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-7900-series/end_of_life_notice_c51-726425.html
mohanak
Cisco announces the end-of-sale and end-of-life dates for the Cisco Aironet 1240 AG Series. The last day to order the affected product(s) is July 26, 2013. Customers with active service contracts will continue to receive support from the Cisco Technical Assistance Center (TAC) as shown in Table 1 of the EoL bulletin. Table 1 describes the end-of-life milestones, definitions, and dates for the affected product(s). Table 2 lists the product part numbers affected by this announcement. For customers with active and paid service and support contracts, support will be available under the terms and conditions of customers' service contract.
http://www.cisco.com/c/en/us/products/wireless/aironet-1240-ag-series/eos-eol-notice-listing.html
Hello willsmith,
Hope you doing good
please refer below
Please go through the below url where you can find the end of sale products and its corresponding replacement products.
