02-21-2018 01:24 AM - edited 07-05-2021 08:16 AM
Dear Members, please suggest me which basic Cisco AP I should purchase for my covered office area i.e. (9x21)mtr.? where concurrent local network users are 10-15. where these users will use ERP client system, MS office and Outlook 2016. All users are under active directory environment. Does can we work effectively in wireless network without any slowness issues ? our budget value is also under Rs.20,000 only. currently my vendor suggested me for WAP121 and WAP150N models. kindly suggest me for better performance.
Rajesh Rathore
03-14-2018 10:24 PM
It is difficult to answer your question without a lot of additional information.
Ideally a site survey should be performed based on your coverage and density requirements which will also identify any RF challenges (physical and/or transmitter interference) in the environment which will help determine if internal antenna APs are suitable or if some external antenna APs are also required (and the type of antenna). The survey would need to be done for 2.4Ghz and 5Ghz.
The clients you will be using must also be considered as they will support different wireless standards (eg 802.11e/k/r/v 802.11ac wave 2, number of spatial streams etc) and have different receiver sensitivity and transmit power characteristics affecting their connection capability and quality. For example, if none of your clients support 802.11ac wave 2 then buying APs that support this may be overkill (unless you want to future proof the solution).
Besides the RF considerations you also need to consider connectivity (switch type, interface speed and type eg mGig) and power (PoE supported eg 802.3af or 802.3at etc).
The following provides a comparison of the features of all Cisco APs:
Access Points - Compare Series - Cisco
The following design guide goes into a lot of detail regarding the points above as well as looking at application requirements. Although the guide is for high density deployments the information can be helpful for most wireless deployments.
Wireless LAN Design Guide for High Density Client Environments in Higher Education - Cisco
03-15-2018 12:40 AM
Hi Rajesh,
if you have ony 10- 15 users then you can go WAP150N or in enterprise 1700 will suffice, but again you need to consider the the Coverage and obstcle also the Application used in the environment also the End devices as mentoned by dmh.
Rgds/Sudhir
