What wireless NIC should I Deploy?!?
da.beaver
I know this is going to be somewhat biased, but I have the unique opportunity to choose a wireless NIC for our company.
It's like this... We have been rolling out many different types of laptops from Dell over the last couple of years and each one has a different built in wireless NIC. We have not had good success from Intel for obvious reasons, we have had great success from external Cisco cards, and good success from Atheros internal chipsets.
What I want to know is what are you using and what works the best. We want to pick one and move forward with only one type of card in the future for all of our laptops.
Thanks in advance for your input.
15 Replies 15
da.beaver
Let me also say that we are trying to stay away from external cards just because they are so easy to steal and lose. We would like for it to be an internal chipset if possible.
Thanks again.
I have seen great success from Intel and Atheros. Atheros is tried and true, and Intel is placing a lot of R&D into 802.11n, even going so far as to partner with Cisco to ensure full compatibility between APs and clients.
Internal adapters are often not as strong as external adapters, but sometimes they have internal antennas that boost their signal. Regardless of the chip/card you go with, find out what the transmit power is and whether there's an antenna. Then set your APs to broadcast at no more than what your clients are capable of.
Leo Laohoo
The link below doesn't necessarily answer your questions directly and won't tell you what Wireless NIC cards are "compatible" but it will tell you which PC/Laptop manufacturers have taken painful lengths to get their products certified by Cisco as "compliant".
Cisco Compatible Extensions Client Devices
http://www.cisco.com/web/partners/pr46/pr147/partners_pgm_partners_0900aecd800a7907.html
Hope this works.
Leo Laohoo
Anybody have experience using Broadcom WLAN NIC?
da.beaver
Thanks for the input. The Cisco compatibility matrix really helps out. I know that we really need to do more testing, but we are going to make some decisions soon.
Thanks again.
Dave
Since you're organization predominantly uses Dell, click on one of the models and it will give you more information of the WLAN NIC.
David did you happen to work at TPI in Johnson City at one time?
From my experience, standardizing on a laptop model or a couple models is the best thing to do. No matter what internal card you use (since most of them will be new) as long as you can standardize on a few, troubleshooting will be much easier. I have clients that standardize on Intel, Broadcomm and Atheros and have no issues once you verify configuration and drivers on both the client and on the wlan. The only issues I see nowaday is when clients still have old devices out there that they haven't migrated out.
-Scott
I think your right. It's so hard to get and stay with one model just because Dell may decide to do away with the model we have 500 of. Then we choose another model and the wireless NIC is a different model. Now we have two NIC's to learn to manage, find updates for, configure, troubleshoot, etc.
We also have issues with some laptops due to having several folks share the same laptop, so we use Windows Zero Config to get the profile we create to work across each users login. With the Intel Utility, we can't do that, and Windows is not the way to manage the wireless profiles. It just doesn't work well in my own opinion.
I know Cisco has a client that will allow the profile to work across multiple logins, is there anything else out there that doesn't cost to deploy?
I knew a guy that said he knew how to get the Intel clients to do it, but I can't get in touch with him.
If you use windows zero, you can push profiles down via GPO, which alot of my clients do. IF you use Interl ProSet or Access Connections, then you can export and import the settings, but that can take forever. Again.... you want to make sure you stick with a single wireless utility or else that can make your life worse.
-Scott
And I think thats what I'm really looking for. What is the single wireless utility that I can use? It needs to be able to handle multiple logins and not cost an arm and a leg. More importantly, it needs to be stable and reliable. I may be asking the impossible here...
No, I've never worked in Johnson City, however I've been through there a couple of times.
David,
Based on the Cisco and Intel wireless partnership, the Intel card is a pretty safe bet.
http://www.cisco.com/en/US/solutions/collateral/ns340/ns394/ns348/ns767/white_paper_c11-492743.html
Also if you look at the AssureWave testing methodology, there seems to be a strong Intel representation.
http://www.cisco.com/en/US/netsol/ns779/networking_solutions_program_category_home.html
We are using the Intel 4965.
dvr0 -
What is the scale of your WLAN environment? We have 20 WLCs and 1750 APs. Our environment supports 1000 7921s and 1000s of other WLAN clients.
We have always had horrible Intel roaming characteristics going back 4 years ago with the 29xx adapters. The 39xx adapters didn't resolve the problem. The 49xx adapters are a little better but still don't roam as well Atheros adapters. I don't have experience with the 59xx adapters.
With Intel adapters, you're always getting notice of "roaming" issues and suggestions that you upgrade your proset drivers. I'm sure they are fine in less dense environments - but for the money, Atheros adapters are rock solid in high density LWAAP environments.
