when i failover from the primary controller to the secondary the AP Group Name shows none even though it was on the correct AP Group Name on the primary.
Are the AP Groups and interface mappings defined on the secondary controller? Are they running the same code? Was the AP's config cleared (did it retain its other config info)?
Learn, share, save
