Does my Radio Work
adam.roth
I am checking a couple of 1310 Bridges. I am finding that some of them won't associate. I have setup a test lab and when I test I get most of them to work and some not. I made sure that the SSID, the WEP-40, encryption and radio mode is set correctly. I have done a write erase, set it to factory and everything under the sun but it appears some of the radios are not transmitting. is there a way to make sure the radio is working???
Adam
p.krane
Level 3
Level 3
Yes, you can ensure that radio is working or not. This can be done by looking at the bridge statictics of individual radio and see whether they are up or down and if up, see the transmit and receive statistics.
