When does a client roam in a CUWN?
Mark Mattix
Level 2
Level 2
I'm having some issues with clients on my network connecting to weak signal APs while there is another AP available with a strong signal. I realize the device should corrently connect to the strong signal and therefore it could be a problem with wireless nic drivers but when a client connects correctly and decides to roam around a building, what part decides to roam to a new AP? If the wireless NIC decides to roam why isn't the card trying to roam if there is a better signal detected?
Is it possible to configure the WLC that when a client reports (via RRM) that their signal is below -65dBm the WLC tells the client to look for a new AP to connect to?
Thanks for any help! -Mark
Stephen Rodriguez
Ultimately the logic to associate/roam is all on the client.
That being said, there is a knob for Client Roaming that can be tweaked, but it requires the client to be ccx certified.  If the NIC is not CCX then it's a moot point.
But yes, make sure the NIC has the latest driver from the manufacturor.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Thank you for the response Stephen!
