11-15-2022 03:24 PM - edited 11-15-2022 03:25 PM
Hello All,
WLC 2504
OS version 8.2.141.0
1-When move ap from default group to other group clients can't get IP address
2-we don't have more then 16 in WLAN ID list (we can't create WLAN With ID 17)
11-15-2022 06:38 PM
You didn't provide enough information. When you add or create a new ap group, you must make sure the wlan's are mapped to the correct vlan. This is how it works for local mode ap's, if your setup is flexconnect, then that is totally different on how the wlan is mapped to a trunked vlan.
11-16-2022 05:37 AM
my setup is local mode and wlan's are mapped to the correct vlan
thank you for replay
11-16-2022 06:55 AM - edited 11-16-2022 06:58 AM
Share some screen shot so we can take a look at the difference between the default and the group you created. The code is pretty old, but really need to see the first four tabs on both, the default and the new.
11-16-2022 08:45 AM
Yes that code is very old and 8.2 in general was abandoned quite early on. You should consider moving to at least 8.3.150.0.
But AP groups should work regardless if you configure correctly.
