When WDSes fail...
jcornford
Level 3
Level 3
I'm hoping that someone can give me a quick answer to this (easy if you've done it) one.
In the event that ALL devices configured as WDSes on a network fail, will the APs that are configured to talk to the WDSes, failover and authenticate clients directly to the authentication servers? Or (I hope not), will they sit there not knowing what to do?
I did try to look it up on the TAC, but could find anything that answered this. I could go and lab it but that would take ages! ;->
o-ziltener
Level 4
Level 4
Yes, this fallback scenario is working.
I did some test but just with wpa.
best regards
Oliver
Excellent, thanks for that.
In my scenario, it just some LEAPing 7920s, but it's only the backend direct auth failover I'm worried about.
Gustavo Novais
Level 5
Level 5
Yep, Just tested it!
