Where are authentication settings stored?
mpkistler
Community Member
I need to be able to automatically set or change the network authentication for many users. All clients are running ACU 6.3. Can this be scripted?
will.shaw
Level 4
Level 4
You can create a profile in the ACU, then export it to disk. The you would just roll that out to the clients and use the import utility.
I suppose, if you wanted the least hassle, you could make it the same name as the existing profiles and just replace the existing file.
There isn't really any way of automating the process, as the details are held on each client.
Thanks for the suggestion, but that wouldn't work when deploying to users in different locations who require unique settings.
Is there someone in Cisco support who can confirm there is or is not a way to change profile settings (specifically the network authentication type) without having the user launch the ACU?
