Why does wpa-psk only work with numbers in autonomous 1140?
tdennehy
Level 2
Level 2
I know it seems rather simple, but for some reason when I try to configure my autonomous 1140, it does not work unless I use numbers.
If I put in my phone number as my key, I can authenticate just fine.  When I change it to some random letters and numbers, nada.
Here's my config:
dot11 ssid MySmallOffice
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 7 0250570E5E5059751D1F5A
Am I missing something?
6 Replies 6
Stephen Rodriguez
when you are putting the key in, are you calling wpa-psk ascii 0 < key >?
the 1142 I have runnign in my house has upper, lower, special and numbers and it works like a champ.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
I have tried everything!  Using the zero, not using the zero, etc.  Only numbers work!
Leo Laohoo
Sorry, just want to make sure I get you correctly, when you configure the WAP, did which method did you enter your password:
1.   wpa-psk ascii 7 0250570E5E5059751D1F5A
or
2.  wpa-psk ascii yipee_ka-yay!
fbarboza
Level 4
Level 4
Are you configuring the unit via the cli or gui, wpa supports upper, lower case and special carracters.
Amjad Abdullah
What is the message that you get when you try to configure letters in the PSK? any messages?
You can put a screen shot. That can help.
Rating useful replies is more useful than saying "Thank you"
fbarboza
Level 4
Level 4
If  you access the AP via the GUi, click on security, then SSID manager and  then on the ? on the left side you will be able to check on this  information.
WPA Pre-shared Key
To  support client devices using static  WEP keys                and WPA  key management, you must configure a pre-shared  key on  the                access point. Enter the key and choose the  appropriate  radio button to specify if you are entering hexadecimal or  ASCII  characters.
If  you use hexadecimal, you must enter 64  hexadecimal character to  complete the 256-bit key. If you use ASCII,  you must enter a minimum of  8 letters, numbers, or symbols, and the  access point expands the key  for you. You can enter a maximum of 63  ASCII characters.
