Why wlan using management interface?
SubnetWarrior
Hi experts!
So i'm learning about my client's WLC, and had some difficulties to understand management interface in wlan.
Why is my client ssid/wlan (named 3cluster) is assigned with managament interface?
This ssid's dhcp is on our core switch interface vlan (int vlan 51), and on that interface vlan there is dhcp relay to my client's dhcp server.
Why don't the ssid/wlan 3cluster is assigned with the interface vlan 51?
Interface with vlan 51 has already in wlc's controller -> interface, but once again, not used by 3cluster ssid/wlan.
The client which is connected to 3cluster ssid has ip address and default gateway with same subnet with interface vlan 51 on core switch.
Sandeep Choudhary
I think your Management interface is in vlan 51 only.
Just paste the output the command:
show interface detailed management
sh run int <>   --> where wlc mgmt port connecte don swicth
Dont forget to rate helpful posts
