Bookmark
Subscribe
4684
WIFI 2800 AP power level (show advanced 802.11 txpower)
ebelschner
Hello
In the past I have used the ---command line of controller ----       SHOW ADVANCED 802.11A txpower
to obtain the power levels from my AP and what each DBm /mw they were
I Can do this on every AP I have ever had
1131
1231
1142
2602
3602
2702
3702
I can do the same on B/G radio as well all these APs  above
SHOW ADVANCED 802.11b TXPOWER
For the new 2800 AP I can can only do this on this on A   show advanced 802.11tA xpower
and get my out put for channels
2800
example-- ch 161          23/20/17/14/8/5/2
FOR B/G nothing
for show advanced 802.11b txpower   nothing comes up   BLANK
I notice in the web interface for the radio  says 2.4 Ghz local for 3800   ( RADIO MODE ) the 1142 and all other APs dont say LOCAL
how do I get the reall TX power on the B/G side on the new AP's this seems stupid
6 Replies 6
aukhadiev
The AP 2800 and 3800 contain a Flexible Radio Architecture, please see link
Understanding Flexible Radio Assignment (software overview)
Therefore, instead of typing "show advanced 802.11b txpower"(cause this AP not contains a dedicated 2.4–GHz radio, it contains a Flexible Radio) you have to type "show advanced 802.11-abgn summary"
No the answer is the CODE doesn't work correctly BUGGY and is fixed after 8.5.120 <-- show advanced tx power doesn't work as the code is broken for B/G with this output before 8.5.120 on the 2800 and 3800 AP
Works after TAC engineer tested and told me to use a later code 8
this AP not contains a dedicated 2.4–GHz radio, it contains a Flexible Radio, so if you type "show advanced 802.11-abgn summary" you can see txpower
This output from my WLC:
(wlc5520-usc) >show advanced 802.11-abgn summary
Member RRM Information
AP Name MAC Address Slot Admin Oper Channel TxPower
APA023.9F66.2AE2 18:80:90:02:3a:20 0 ENABLED UP 13* *2/6 (13 dBm)
APA023.9FAE.EDF2 18:80:90:0e:23:20 0 ENABLED UP 5* *5/6 ( 4 dBm)
AP00A3.8EFA.DF50 40:ce:24:fb:cc:40 0 ENABLED UP 13* *5/6 ( 4 dBm)
APA023.9FAE.EDC4 18:80:90:0e:20:40 0 ENABLED UP 13* *5/6 ( 4 dBm)
APA023.9FAE.ED8E 18:80:90:0e:1c:e0 0 ENABLED UP 9* *2/6 (13 dBm)
look if your a CISCO employee go look at case # SR# 684073088 AIR-CT2504-5-K9
I have my answer now and the issue is corrected--by a tac engineer.  go look at the notes under the case
the output did not work with the Show advanced 802.11b tx power with other code -and has been corrected with the 8.5.120 code  advised by cisco tac engineer for 2504
I understand the radio is different on this ap -- your posting out from a 5520
my case was a 2504
when I used the show advanced 802.11-abgn summary it also did not the output
I use RF profiles with max and Min ranges and needed the REAL output which worked on the show advanced 802.11a txpower but not 802.11b txpower
IT WORKS NOW <----WITH A CODE UPGRADE --- PER ENGINEER   SR# 684073088 AIR-CT2504-5-K9     it displays output now when you type the command
Thanks for info,
in release that my wlc running (8.2.167.6) "show advanced 802.11b txpower" not working, but "how advanced 802.11-abgn summary "  give some info, not such detailed, but txpower is present
Excuse for troubling...
Guy -it is FIXED now??? and the case is closed ???if you feel the need to hound someone --->go to the tac engineer that advised me at CISCO if you work at CISCO call--> talk to him
I gave you the case# there are screen caps of the output not working if you feel your better then him please connect him and tell him hes doing a bad job fixing and advising
The closure of the case the is resolved
