Wifi 6 APs
cisco8887
Level 5
Level 5
Hi all,
if you buy 9117 APs which are wifi 6 , would it support 802.11b and a / very old standards on its own ?
if yes, would every one need to switch to old standard if one device is say 802.11b
Remember back in the days, if you had b/g enabled and had one device in b then every client would connect using B so essentially you were not using g standard.
i want to know if this is the same case here
5 Replies 5
Mark Elsen
   >if you buy 9117 APs which are wifi 6 , would it support 802.11b and a / very old standards on its own ?
Yes
   >yes, would every one need to switch to old standard if one device is say 802.11b
 No
   - Not true clients decide connecting-parameters by themselves using most-optimal parameters
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
thanks for this
if you have 802.11b/g and one client was on b, my understanding was evey client would move onto B as G is no longer supported, is this incorrect ?
I was checking if this was the case with new standards and you mentioned no
PHY 802.11b and 802.11g are both supported across al AP models
Saludos,
Rafael - TAC
"if you have 802.11b/g and one client was on b, my understanding was evey client would move onto B as G is no longer supported, is this incorrect ?
Not exactly correct. If you have 11b client on the cell (BSS), then 11g clients have to use a protection mechanism (RTS/CTS or CTS-sefl) in order to let 11b clients know about communication going to happen. Those RTS/CTS frames are using data rates that 11b client can understand, so they will stay quiet (for a time value set in Duration/ID field) and that helps to prevent collisions.
Refer "Protection mechanism for non-ERP" for more details
https://mrncciew.com/2014/11/02/cwap-802-11-protection-mechanism/
Even two 802.11g clients communicate they have to use this protection mechanism. Once you use the protection mechanism, those two 802.11g clients can use 802.11g higher rates (6,9,12,18,24,36,48,54 Mpbs) for their data frame transmission.
So every client move to 802.11b is not exactly right in this context. Hope that clears
Rasika
*** Pls rate all useful responses ***
And of course it means that you cannot disable the b data rates.
Please click Helpful if this post helped you and Accept as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
