wifi ssid disappeares
bluesea2010
Level 5
Level 5
The client cannot see all SSID. If there are 5 SSID  4 will be shown.
I am using a cisco  5760  controller.
and also for some clients, local websites are slowly loading. others it works fine.
Before I had a slow browsing experience, then I changed the fiber cable from the distribution to core. It worked fine.
That was very recent. So I don't think it is any layer 1 issue.
So my question if it is any layer one issue it should affect the wired clients also?
How to verify
marce1000
           - Have sanity check of the controller-configuration with : https://cway.cisco.com/tools/WirelessAnalyzer/
 M.
