Wifi Troubleshootings
jain.manish94
Wifi credentials are not working in mobile, same credentials are working fine in Laptop.
23 Replies 23
thanks for reply
but please can you tell me what in security 802.1x disabled and enabled in Auth key management.
Check the attached pic and do like this..
Dont forget to rate helpful posts
yes , but i want to know about 802.1x , why it is happend when i am using 802.1x with wep users are not connecting by mobile
did you conifgure your mobile correctly with 802.1x+wep ??
Chekc this doc: http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/82135-wlc-authenticate.html#conf-6
If its not working then use wpa2/802.1x and try again.
Q- As per the below snapshot, you can see, On 48port switch, 24 Port and the uplink port( from NM module) is connected on ASIC and the rest port is connected to another ASIC. How traffic flow from Port1 to Port25( Assume Stack cable is not connected).
i just copy this diagram threw internet and paste here. please reply ASAP.
PFA...  do you have any idea regarding this
No Idea about switch ASICs.
what happen , did you find anything
mohanak
What kind of authentication protocols used?, will the mobile support those protocols?, any other mobiles able to connect to same network?
please let me know one thing , can we check in wlc that android can access wifi with same credentials which we are using to connect our lapi...
