wifi wep key
prashantrecon
Hi All,
I have a cisco Aironet 1200 series Access point and currently i am using wep with 128 bit .My concern is that i want to change this key with current SSID .
My current SSID is ABtc
My current key is abcdefgh12345
when i try to change the key its give me error
"encryption key must be 26 hexadecimal characters"
Angus Bishop
HI Prashant,
The current key you are using is ASCii type which want exactly 13 charachers .
Now you are trying to give a hexadecimal key which require 26 characters .
Try using ASCII and let me know .
Angus
can you plz send me step by step gudie to configuration in cisco aironet 1200 using gui or cli.
hi my setup is as below
dh#config t
dh(config)#int dotradio0
dh(config-if)#no encryption key1 size 128bit 7 1752614c0554547554FE transmit-key
now i have given
encryption key 1 size 128bit 7 1234567891234567891234567891 transmit-key
then when i try to connect this Access-point
i got error on my laptop
""the network password needs to be 40bits or 104bits depending on your network configuration.
this can be entered as 5 or 13 ascii characters or 10 or 26 hexadecimal characters"
Prashant,
     Typically in the line you pasted "encryption key 1 size 128bit 7 1234567891234567891234567891 transmit-key"
the 7 after 128bit means that the key following it is encrypted so the AP thinks 123456789123456789.. is actually the encrypted value, try entering the key like this
encryption key 1 size 128bit 0 1234567891234567891234567891 transmit-key
And see if that resolves your problem.
