Will a NAC appliance work with Meraki WL
rramlal
Hi All,
I have a customer that presently uses the cisco meraki wireless solution and would like to have a NAC appliance installed in there environment. Will Cisco NAC support the meraki for access control?
George Stefanick
No, I don't believe so ..
+1
Hi George,
Thank you for your response. Can you provide some documentation that states this or indicate where i can find the documentation?
Yes Sir.. Check this link for supported devices with Cisco ISE
http://www.cisco.com/en/US/docs/security/ise/1.0.4/compatibility/ise104_sdt.html
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
