Win XP clients not authenticating using PEAP
A customer has RADIUS running on a Win Server 2008 R2 machine, has Autonomous 1140 APs and a mix of Windows 7 and XP Pro clients.  Using PEAP as the authentication method the Win 7 clients can access the WLAN, but the Win XP clients cannot.  The Win XP clients are at least SP2.  I am doing some research before going to site on Friday and wanted to poll the community.  I found an older post speaking to a MS Hotfix under KB#885453, but it referes to "third-party RADIUS servers," not MS servers.  http://support.microsoft.com/?kbid=885453
Any other feedback or suggestions are welcome and appreciated.
14 Replies 14
Scott Fella
When you say PEAP, are you using AD credentials (username & password), or machine authentication. Windows XP doesn't do machine authentication. Unless you do a registry hack.
http://support.microsoft.com/kb/929847
-Scott
Thanks for the quick bounce-back.  Yes, I had confirmed with the customer that they were trying to use AD credentials.
Then you should have no problems. The main issue I see with devices having issues is when using both WPA/TKIP and WPA2/AES or a mix of both. Also when client load balancing is enabled can cause issues. You best bet is to post the show WLAN and the show sysinfo of the WLC to start. Also a debug client and the failure log on the radius server.
This would be good to start with troubleshooting.
-Scott
Thanks for the feedback.  The APs are autnomous, so no controller.  But, the debug client, and maybe debug radius commands as well as radius server failure log should give me more info.
That will give you more detail for sure. Also make sure your only using one type of encryption. That is important!!!
-Scott
i've checked the WZC on both a Win XP and Win 7 client and they both are set for WPA2/TKIP only.
The AD user for the Win XP client is in the AD user group referenced in the WAP network policy on the RADIUS.
any input is appreciated.
That is wrong... you should be using WPA2/AES not WPA2/TKIP.  Change it to WPA2/AES and test again.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
I've flipped the settings to all combinations, currently on WPA2/AES and the Win 7 client still connects and the Win XP does not.
Try WPA/TKIP now... maybe the hardware on the XP machines don't support AES.
Scott
-Scott
That combination fails as well.
I've double checked the Radius policy and its a match of what's described in the Cisco SBA doc for setting up a win 2008 server.
Thank you
Take a look at this doc and see if its setup similar.  I don't know what else you can do.  If the drivers have been updated, then it seems like you would see a failure of some sort that would tell you what is happening on the radius logs.  Have you tried with multiple XP machines and not just one or two?
https://supportforums.cisco.com/docs/DOC-17512
http://www.windowsnetworking.com/articles-tutorials/windows-server-2008/Setting-up-Wi-Fi-Authentication-Windows-Server-2008-Part1.html
Scott
-Scott
I have 3 XP laptops i'm using to test.
Here is the AP's config:
test-ap#show run
Building configuration...
Current configuration : 2506 bytes
version 12.4
no service pad
service password-encryption
hostname test-ap
enable secret 5 $1$kpqT$UTsafjX/60V8nWu7e8s/90
aaa new-model
aaa group server radius rad_eap
server 192.168.1.7 auth-port 1645 acct-port 1646
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius rad_eap1
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login eap_methods1 group rad_eap1
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 syslog
dot11 ssid AP
   authentication open eap eap_methods1
   authentication network-eap eap_methods1
   authentication key-management wpa version 2
   guest-mode
username Cisco password 7 072C285F4D06
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid AP
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
encryption mode ciphers aes-ccm
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address 192.168.3.10 255.255.252.0
no ip route-cache
ip default-gateway 192.168.1.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server host 192.168.1.7 auth-port 1645 acct-port 1646 key 7 12380614412B5        550787A
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
end
test-ap#
Okay, leave it as wpa/tkip for testing and once you make the change, does the windows 7 devices still connect except for the windos XP?
dot11 ssid AP
   guest-mode
no ip address
no ip route-cache
Scott
-Scott
Here is a troublshooting link... use these debug commands and post what shows up
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801bd035.shtml#tshoot
Scott
-Scott
