Wired passive client
s.hellman
Level 4
Level 4
We have a device with static IP connected to a Remote LAN on a 1815W, that we cant communicate with. I guess it behaves as a passive client.
All guides I can find about passive clients are about clients connected to WLANs. Is there a way to get passive clients working on Remote LANs?
6 Replies 6
I think this because your enable dhcp required'
So solution is add new ssid and disable this option.
MHM
No, the DHCP required is not enabled, we have other devices with static adresses on the same Remote LAN that are communicating.
There are four workaround for passive client
We above cover one
Check other three
MHM
Thanks for trying to help. We have 5520-controllers running 8.10.196.0 software, end the commands in the guide you sent dont exist.
We have now solved the problem with a workaround. We have put a switch at the remote location and connected the device to the switch, and then put a static route in the core pointing the device ip to the switch.
