Wireles Module Interfaces
Hello Dears,
I have wireless module, and when i do sh ip int brief command in router(whis is module connected) i see two interfaces:
1)Service-engine interface
2)Integrates-services-engine interface
What is the difference between them
Module has only one gigabyte interface
Please explain me what is this two interfaces for
thank you
Scott Fella
The Integrates-services-engine interface is the communication interface between your router and the wlcm. This is what needs to be configured. The services-engine interface I believe just shows the modules you have installed.
-Scott
Ok, but where i can see Gigabyte-interface
show ip int br - do not show it
Can you post what you are seeing.... that makes it easy to explain then.
Have you read through this document?
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t15/rockynm.html#wp2021802
-Scott
