Wireless 1200 AP Authentication Failed
rodonohu1
Level 3
Level 3
I'm prett new to setting up Cisco WAP. I have tried to copy the config from a working one in another other and changed it to suit my own. I'm attaching a config. The problem is that the AP doesnt automatically get picked up by Wireless cards and when i manually set it up, i get authentication issues - DOG11-7-Auth_Failed from the station MAC-ADDRESS
Any idea? I am confused how the Vlan i have set it up on communicates. Please help?
heres a link. Haven't experienced this issue myself but APPEARS to be a possible misconfiguration on the client end.
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a00801df0ea.shtml
7 Replies 7
robert.wright
Level 5
Level 5
Suggestion before i look at anymore of your config. Please sanitize all of your configs you post on the forums. You have a few passwords in there.
Just glancing over i dont see anything that sticks out, have you reference the associated log files on your radius/acs boxes for failed attempts? Also appears your authenicating via mac address so possibly the mac addy isnt present as an authorized device?
Thanks for the feedback.
I've been working on alot and built up the config again from scratch.
the problem is definatly around the authentication.
When I set it up as follows, I can't see the wireless netork:
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 key 1 size 128bit 7 3EF6C4C5A0DD03D60ACFBC40F93B transmit-key
encryption vlan 1 mode wep mandatory mic key-hash
encryption vlan 18 key 1 size 128bit 7 02DC3457EC1AAFC9DF2FAECDF0DF transmit-key
encryption vlan 18 mode wep mandatory mic key-hash
ssid EmP1R3D
vlan 18
authentication open mac-address mac_methods eap eap_methods
authentication network-eap eap_methods mac-address mac_methods
but if i put it in guest mode, then i can see the secured network but can't log on to it. When i try to connect it just times out trying. On the client, it doesn't seem to be able to exchange keys,etc. this is where I am in the dark and have difficulty figuring it out.
I've checked the ACS box and it shows on passed authentications that its fine. I just can't get up user authentication box at this point on the client.
I've also checked this on my ACS failed attempts now: I keep getting the following that points it could be related to PEAP
EAP-TLS or PEAP authentication failed during SSL handshake
where could this issue lie?
Excatly. I found this yesterday and it worked. The client didn't have the correct Certs so it couldn't authenticate. Cumbersome process but worked.
Thanks for your helpe Robert.
m.rana.ku
Level 3
Level 3
In the following video step by step process has been shown How to Configure Cisco AIRONET 3602i Autonomous/Standalone Access Point using CLI with WPAv2 Authentication Key.
https://www.youtube.com/channel/UCmZZ2BNGXQH1HPS3uIVnr7A?sub_confirmation=1
https://www.youtube.com/watch?v=JkUfTXuwj2U
============ For 2.4 GHz Radio Interface ============
Step 1: Access Cisco AP|Reset AP| Assign static IP for BVI1 Interface |Default-gateway IP
ap>enable
Password: Cisco [Cisco AP default Password]
## Reset the Access Point with pressing and holding mode button ##
ap#configure terminal
ap(config)#interface bvI 1
ap(config-if)#ip address 192.168.2.4 255.255.255.0 [According to my network setup]
ap(config-if)#exit
ap(config)#ip default-gateway 192.168.2.1 [According to my network setup]
Step 2: Creating SSID | Authentication | Applying WPAv2 Authentication
ap(config)#dot11 ssid Cisco_WLAN [ Create SSID named Cisco_WLAN]
ap(config-ssid)#guest-mode [Broadcast SSID]
ap(config-ssid)#authentication open [allows any device to authenticate]
ap(config-ssid)#authentication key-management wpa version 2 [Applying WPAv2 Authentication]
ap(config-ssid)#wpa-psk ascii Cisco123 [Applying WPA Shared Key ]
ap(config-ssid)#exit
Step 3: Enable Encryption to 4.2GHz Radio interface | Apply SSID to interface| Enable Radio Interface
ap(config)#interface dot11Radio 0 [Selecting 4.2 GHz Radio interface]
ap(config-if)#encryption mode ciphers aes-ccm [Enabling CIPHER AES-CCM Encryption to interface]
ap(config-if)#ssid Cisco_WLAN [Applying SSID to Radio interface]
ap(config-if)#channel least-congested [Selecting Channel type]
ap(config-if)#no shutdown [Finally Enabling the 4.2 GHz Radio Interface]
ap(config-if)#exit
ap(config)#exit
================ For 5 GHz Radio Interface =======================
ap(config)#dot11 ssid Cisco_WLAN 5GHz [ Create SSID named Cisco_WLAN 5GHz ]
Step 3: Enable Encryption to 5 GHz Radio interface | Apply SSID to interface| Enable Radio Interface
ap(config)#interface dot11Radio 1 [Selecting 5 GHz Radio interface]
ap(config-if)#ssid Cisco_WLAN 5GHz [Applying SSID to Radio interface]
ap(config-if)# channel 36 [Selecting Channel type]
ap(config-if)#no shutdown [Finally Enabling the 5 GHz Radio Interface]
ap(config-if)#exit
ap(config)#exit
Cisco #Configure_AP #IT_Support_People IT Support People Facebook Page: https://www.facebook.com/IT_Support-PeopleDesktop-Support-111268543923018 Link for Other Related Videos: Configure Cisco Access Point Standalone/Autonomous using GUI with WPAv2 Authentication Key: ...
