Wireless 4K Streaming
PAR
This is just a general query about wireless capacity. Traditionally we have used the 30 users per AP model for capacity, however, if you have a customer who has a requirement that the wireless infrastructure must support 4K video streaming is there a general rule for how many users per AP?
Thanks for any advice, much appreciated.
11 Replies 11
Scott Fella
Users per ap varies and you would need to really test to see how many devices can provide good 4k.  Also note is there is any compression or transcoding that is done prior or not.  Can't really tell you what to go with as I haven't really seen post in regards to this and or testing.
-Scott
You might want to reference this Meraki guide also.  Should help, since it has calculations.
High Density Wi-Fi Deployments - Cisco Meraki
-Scott
PAR
Thanks Scott, I'll take a look.
saravlak
There're many factors to account for, following doc is old but most of the principles do apply.
Cisco Unified Wireless Network Solution: VideoStream Deployment Guide
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-1/VideoStream/b_Cisco_Unified_Wireless_Network_Solution_VideoStream_Deployment_Guide.html
Wireless High Client Density Design Guide
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-7/b_wireless_high_client_density_design_guide.html
PAR
Thanks Saraviak, I'm trying to work through an example: -
If you had 150 users in a building and they all wanted to do 4K video streaming (assume 15-18Mbps), at the same time, how many access points would be required? And how would this change between clients who support 2 spatial streams and connect via Wifi 5 or Wifi 6?
I believe Wifi 6 can support 8 clients simultaneously, whereas Wifi 5 its only 1, which would have an impact on the backbone connections, MultiGig ports for Wifi 6 access points.
Appreciate the support.
to start with, Try test with one AP and 15 clients.
Rough estimate only:
WiFi 6 APs. 10+ APs ==> depends upon the environment/setup/config.
Use Videostream feature.
40mhz, 5ghz only wlan, lower data rates disabled.
connecting datarate, SnR and RF Bandwidth availability matters.
less likely to throttle AP's wired port.
Thanks, appreciate the response.
I was mainly looking at the planning process as opposed to the actual configuration side.
Before we get the config side if a customer says I want to support these 150 users 4K streaming, what is the maths you would give them to say "Mr Customer you need x access points based on these figures".
4.4 Video Performance
https://miercom.com/pdf/reports/DR201007G.pdf
it depends on so many factors, i'd tell cust that it takes 10+/X APs as min.
I was just about to post the link to that Miercom report but you got there first lol
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Lol 🙂
Cheers guys I'll take a look at the report.
