Wireless Access Client
shanakawijayathunga
Community Member
I v got 1121_G WAP can any one tell me How many clients can get access to WAP?
jaichauh
Level 3
Level 3
Hi!
The AP has the physical capacity to handle 2048 MAC addresses. However, because the AP is a shared medium and acts as a wireless hub, the performance of each user decreases as the number of users increases on an individual AP. Ideally, not more than 24 clients should associate with the AP because the throughput of the AP is reduced with each client that associates to the AP.
-Jai
JC
Thanks Jai i v got 30 students in each class's would you think it will be able to handle it. and is this AP's can manageb by WCS?
Yes, AP would be able to manage these many clients. However, as I said AP's are the wireless hub, so it would affect the signal strength.
If you have LWAP and WLC, you can manage them through WCS.
Autonomous AP's can't be managed by WCS.
-Jai
JC
