Wireless AP 1230 and Peap authentication
mehdi.amini
I have access point running on 12.2(13)JA3 and a gateway 450 with an Inter pro/wirelss 2100 and all is fine when using LEAP. Once I change to PEAP and install the certificate it fails to authenticate and the wireless keeps failing/authentication/disabling.
jczaplewski
The best way to start testing PEAP when coming from LEAP is to uncheck server certificate validation. Depending on the client you're using there's an option for this. WinXP has it under the advanced area of authentication. Uncheck that, then test your PEAP. IF that works, then you know you can focus on the certiciate mutual authentication portion of your deployment.
