Wireless AP - Bridge Mode
Mahmoud Bakri
Community Member
Hello ,
I am working on a wireless outdoor solution.
I have 20 APs ( 1532I ) that should provide internet access to an outdoor area. ( Mesh topology )
Only 5 APs can be reached with Ethernet connection and therefore would be connected to the WLC.
1)Those 5 APs should be discovered by the WLC and should be configured as RAPs ?
2) How can I configure the remaining 15 APs to reach those RAPs ? they should be in autonomous mode at first ?
Thanks ,
Mahmoud
Dennis Kline
Level 3
Level 3
First, if at all possible, you should pre-configure and stage everything in your shop or lab before installing in the field.
- Make sure you have all of the mac address loaded in your WLC mac filtering list
- Configure your RAPs and ensure they connect to the WLC.
- When you turn on the mesh radios, since they have nothing connected to their Ethernet port they will assume they are a MAP,  and they will begin to search for a RAP to connect with.
- Once everything is connected and working, you can begin to segment mesh radios by bridge group and do any final configurations.
[email protected]...(It takes an Act of God to fade a wireless path, but any fool with a backhoe can cut fiber)
