Wireless AP connectivity
SOLID
Frequent Visitor
Frequent Visitor
Hello Everyone,
I am having issues in one of my remote location where all the cisco APs access point will suddenly disconnect from the controller and after a while all the AP will connect back.
Pls i need assistance to resolve this issue.
Paul
Mark Elsen
    - This could also be an external network hiccup on the particular intranet
    - Configure a central syslog server for all switches where APs are connected to , and check the resulting logging on the syslog
       server
    - Configure global ap syslogging on the controller to the particular syslog server too
    - Use the same syslog server for the controller too
                          All of this may lead to enhanced insights ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Leo Laohoo
What is the model of the WLC & AP?
What firmware is the WLC on?
Rich R
If all the APs at a remote location disconnect at the same time that would suggest a problem with the backhaul between the remote location and the WLC.
Check for flaps and/or congestion in that backhaul path.
What reason do the WLC and AP logs show for disconnection?
You can use IP SLA on a router or switch to monitor the connectivity.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
