Wireless AP dropping users
Madhan Kumar
Dear All,
I have installed an Access point AP1252AG-A-K9 successfully and it was working fine last 7 months. All of sudden it is keep on dropping users. I mean users are disconnected from the AP and then reconnected. I am unable to understand the exact issue. May be an ios issue?. Kindly suggest.
Thanks you
Sincelery
R.MADHANKUMAR
Nicolas Darchis
Please provide the console output of the AP (or telnet with "term mon") when it drops users. It should mention the reason of the client disconnect.
It can be interference, have you checked for other APs/SSIDs/non-wifi devices ?
Which band are you using ? 2.4 or 5ghz ? How many antennas did you connect ?
Nicolas
Hi Nicolas,
Please find the req information here. This may help you to find out the exact issue.
show veriosn sion
Cisco IOS Software, C1240 Software (C1240-K9W7-M), Version 12.3(7)JA5, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 27-Jul-07 14:03 by kehsiao
ROM: Bootstrap program is C1240 boot loader
BOOTLDR: C1240 Boot Loader (C1240-BOOT-M) Version 12.4(13d)JA, RELEASE SOFTWARE (fc2)
3.24_Hyd_AP uptime is 4 weeks, 4 days, 55 minutes
System image file is "flash:/c1240-k9w7-mx.123-7.JA5/c1240-k9w7-mx.123-7.JA5"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco AIR-AP1242AG-A-K9 (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
Processor board ID FOC14025LFK
PowerPCElvis CPU at 266Mhz, revision number 0x0950
Last reset from power-on
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 9C:AF:CA:01:79:EE
Part Number : 73-9925-07
PCA Assembly Number : 800-26579-06
PCA Revision Number : A0
PCB Serial Number : FOC14025LFK
Top Assembly Part Number : 800-29232-02
Top Assembly Serial Number : FCW1403U08P
Top Revision Number : A0
Product/Model Number : AIR-AP1242AG-A-K9
Configuration register is 0xF
3.24_Hyd_AP#show flash
Directory of flash:/
2 -rwx 2444 Apr 1 2002 20:15:01 +00:00 config.txt
3 -rwx 1048 Apr 1 2002 20:15:01 +00:00 private-multiple-fs
4 drwx 320 Jan 1 1970 00:04:44 +00:00 c1240-k9w7-mx.123-7.JA5
147 -rwx 1106 Apr 1 2002 20:15:01 +00:00 private-config
148 -rwx 257 Mar 1 2002 00:00:10 +00:00 env_vars
15998976 bytes total (11545600 bytes free)
3.24_Hyd_AP#show run
Building configuration...
Current configuration : 2444 bytes
version 12.3
no service pad
service password-encryption
hostname 3.24_Hyd_AP
enable secret 5 $1$yO2w$8qGmBeYRFoHJXWJTKfcpb0
ip subnet-zero
ip domain name tpilhyd.com
no aaa new-model
dot11 ssid TPC0801
authentication open
authentication key-management wpa
wpa-psk ascii 7 0127140D0F02042D711B
power inline negotiation prestandard source
username diebinladen privilege 15 password 7 0604462B185D290A0E1A154E
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid TPC0801
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root access-point
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
More bridge-group 1 spanning-disabled
hold-queue 160 in
interface BVI1
ip address 10.1.3.24 255.255.248.0
no ip route-cache
ip default-gateway 10.1.0.11
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community 253240100 RO
snmp-server community 253240101 RW
control-plane
bridge 1 route ip
line con 0
session-timeout 15
exec-timeout 15 0
logging synchronous
login local
length 4
transport preferred all
transport output all
line vty 0 4
session-timeout 15
exec-timeout 15 0
logging synchronous
login local
length 4
transport preferred ssh
transport input ssh
transport output ssh
line vty 5 14
session-timeout 15
exec-timeout 15 0
logging synchronous
login local
length 4
transport input ssh
line vty 15
session-timeout 15
exec-timeout 15 0
login local
length 4
transport input ssh
end
3.24_Hyd_AP#show intre erfaces
BVI1 is up, line protocol is up
Hardware is BVI, address is 9caf.ca01.79ee (bia 003a.982c.6fa0)
Internet address is 10.1.3.24/21
MTU 1500 bytes, BW 54000 Kbit, DLY 5000 usec,
Last input never, output never, output hang never
Input queue: 6/75/0/0 (size/max/drops/flushes); Total output drops: 0
5 minute output rate 2000 bits/sec, 2 packets/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
27101 packets output, 12012252 bytes, 0 underruns
Dot11Radio0 is up, line protocol is up
Hardware is 802.11G Radio, address is 003a.982c.6fa0 (bia 003a.982c.6fa0)
MTU 1500 bytes, BW 54000 Kbit, DLY 1000 usec,
Last input 00:00:26, output 00:00:00, output hang never
Input queue: 0/75/10004/0 (size/max/drops/flushes); Total output drops: 248
Queueing strategy: fifo
Output queue: 0/30 (size/max)
5 minute output rate 4000 bits/sec, 5 packets/sec
1489298 packets input, 354144047 bytes, 0 no buffer
Received 37703 broadcasts, 0 runts, 0 giants, 0 throttles
13968267 packets output, 3023461463 bytes, 0 underruns
61050 output errors, 0 collisions, 2 interface resets
0 lost carrier, 0 no carrier
Dot11Radio1 is reset, line protocol is down
Hardware is 802.11A Radio, address is 003a.982d.f800 (bia 003a.982d.f800)
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
FastEthernet0 is up, line protocol is up
Hardware is PowerPCElvis Ethernet, address is 9caf.ca01.79ee (bia 9caf.ca01.79ee)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Full-duplex, 100Mb/s, MII
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/160/0/0 (size/max/drops/flushes); Total output drops: 0
Output queue: 0/40 (size/max)
5 minute input rate 23000 bits/sec, 17 packets/sec
5 minute output rate 3000 bits/sec, 3 packets/sec
32591885 packets input, 2813497061 bytes
Received 12286244 broadcasts, 0 runts, 0 giants, 21 throttles
0 watchdog
1826411 packets output, 400193953 bytes, 0 underruns
3.24_Hyd_AP# exit
Thanks & Regards
R.MADHANKUMAR
That's pretty much everything except the information I requested in my previous post 🙂
If you can't get the output of the AP when it drops clients live, you can try "show log" and see if it appears there. But please reply to the other questions as well
