Wireless AP in-line power
JAYESH RAMAIYA
I have installed an Cisco access point that is connected to a Cisco power invertor.
The status light is contantly pink with on other green lights.
I read somewhere that the AP needs 56 watt of power. Are the POE convertors able to aupply this?
Stephen Rodriguez
What type of AP did you install?  If it's a 1552 then yes it needs that much power. If it's one of the indoor AP, it only requires 15.4w.
Powering Options
1552E/1552EU
• 90-480 VAC, 50-60 Hz
• 12 VDC
• PoE with power injector
1552C/1552CU
• 40-90 VAC, 50-60 Hz, quasi-square wave, Power over Cable
• 12 VDC
1552H
• 100-240 VAC, 50-60 Hz
• 12 VDC
1552I
• 110-277 VAC, 50-60 Hz
• 12 VDC
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Thanks for your reply Stephen.
I have a AIR-AP1242AG-E-K9
Cisco Aironet 802.11 Access Port
What power would I need for this?
Hi Jayesh,
AP1242 would requires at least 12.94W at 48 VDC. Just check on the AP console, if you are able to see any logs there for the bootup process.
Najaf
This would take either POE from a switch, or a pwrinj3
HTH,
Steve
HTH,
Steve
