Wireless AP issues
Artezys79
Hi All,
I am trying to replace my Meraki switch with C9300 but keep Meraki AP.
First step was to replicate settings and apply to the C9300, however Meraki AP isn't able to resolve dnslookup on tagged traffic but all is fine on untagged traffic. DHCP server resides on the switch with two number Vlan's linked to the AP with different SSID.
From the VLAN's gateway, which belongs to SSID's I am able to ping 8.8.8.8 but from the client on the same subnet only up to the uplink.
6 Replies 6
Brash
Meraki Community All-Star
Sounds likely to be an issue with VLAN tagging somewhere along the line (double tagging, native tagging etc).
What's the VLAN config on the switchports between the AP and the gateway?
Are you tagging the management VLAN on the Meraki AP or is it untagged?
My gateway resides on the router, then via uplink onto the switch with vlan's allow all and the onto the switch port with native vlan 1, then allowed vlan's list is 1,1515 (represents SSID),2020 (and another SSID).
Management is untagged on meraki AP.
Philip D'Ath
What VLAN tag is the SSID using?
Is the switch port that the AP plugs into configured as a trunk port, using a native VLAN that is not the same as the tag, and is the tag allowed on that port?
What is te default gateway for that VLAN? If it is the switch, does the MX have a static route pointing to the switch for that VLAN subnet?
I am using VLAN 1515 and VLAN 2020 for two different SSID's
The port where AP is plugged in is in trunk mode with the following VLAN's, 1,1515, 2020 along with native VLAN 1. Below is the extract from my switch config.
Default gateway is .1 address on the switch where switch provide DHCP services to the AP. In my case, I have static routes for VLAN 1515 and 2020 assigned on the Cisco NGFW device and pointing to the uplink address on the switch.
Just spotted that in my config VLAN 1 doesn't have any IP assignment, but not sure what has to be there. On my Cisco NGFW I have VLAN 1 with the subnet which is used for Meraki AP.
Spoiler
Config
no ip domain lookup
ip dhcp excluded-address 192.20.20.0 192.20.20.1
ip dhcp excluded-address 192.15.15.0 192.15.15.1
ip dhcp pool WIFI
network 192.15.15.0 255.255.255.0
default-router 192.15.15.1
dns-server 8.8.8.8 8.8.4.4
lease infinite
ip dhcp pool WIFI-S
network 192.20.20.0 255.255.255.0
default-router 192.20.20.1
lease infinite
no ip igmp snooping vlan 1011
login on-success log
ipv6 nd raguard policy HOST_POLICY
udld enable
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
ip address 10.66.102.2 255.255.255.0
negotiation auto
interface TenGigabitEthernet1/0/1
description Uplink
switchport mode trunk
ip arp inspection trust
logging event trunk-status
load-interval 30
ip dhcp snooping trust
interface TenGigabitEthernet1/0/2
switchport trunk allowed vlan 1,1011,1515,2020
speed auto 5000
interface Vlan1
no ip address
interface Vlan5
description In-band Management
ip address 192.168.5.10 255.255.255.0
interface Vlan35
description Uplink
ip address 175.35.69.2 255.255.255.248
interface Vlan100
description Data
ip address 192.168.100.10 255.255.255.0
interface Vlan1515
description WIFI
ip address pool WIFI
interface Vlan2020
description WIFI-S
ip address pool WIFI-S
Philip D'Ath
What happens if you give the switch a static IP address in VLAN1515 and 2020?
Thank you for your advise.
It appears that issues was with the switch, as ip routing wasn't enabled, and after enabling it routing start working as expected.
