Wireless AP
fatalXerror
Level 7
Level 7
Just have some questions,
1. Anybody knows other wireless design for guest besides from Foreign-Anchor?
2. Is the wireless AP capable of running multiple virtual context/system and connect each context to separate controllers?
thanks
Hi @fatalXerror
 The design based on foregn and anchor was built thinking in security but if security is not a concern, the auternative would be the Classic design which is only one WLC.  Rather than that, I dont see any other design.
For AP context, no. The AP is very limited in configuration.  It derives its config from the WLC and from only one WLC.
Hi @fatalXerror
