Wireless APs spanning a very large room
cisco515
Greetings,
Thanks in advance for any and all help you may provide.
I am hoping to provide wireless connectivity to a long, fairly narrow building...essentially open space for a few hundred feet. (Building is longer than it is wide...and is 200-300 feet long or thereabouts.)
I would undoubtedly need several APs to cover the footprint of the building...but:
-How do I keep the APs from conflicting with one another?
-Could I assign the same SSID, with a different channel ID? Would this work?
-Would it be better to get ONE AP, and somehow amplify the signal from a central point in the building?
-I have heard of an AP/Bridge from Cisco...if this is the solution, could you point me in the right direction (technical docs, whitepapers, model numbers and specs, etc.).
Thanks again for the help!
Best regards,
Sean G.
kagodfrey
Level 3
Level 3
Hi Sean
A lot of questions there so I'll do my best to answer what I can.
You may be able to use a single AP mounted centrally in the building depending on where you are (and hence the power regulations associated to your country), the level of throughput you need, and the actual size of the building. Here in the UK we are limited to 802.11b (currently) and 50mW radios, but even with 2.2dBi antennaes the AP has a coverage radius of about 40m at 11Mbps - so, depending on whether you are nearer the 200ft or the 300ft mark will define whether you need another AP a bigger antennae (bigger antennae, bigger range and/or different coverage pattern). You need to perfrom a site-survey in the area to be certain. Also you need to consider the number of clients that will be using the WLAN - being as it is a shared media you get performance equivalent to a 10 meg hub scenario so you would be looking at a maximum of 20 users with 'normal' traffic patterns (email, browsing etc). More users will mean more APs - and you can co-locate up to 3 in one area, but you must use different channels (for 3 APs the only channels that will do this are 1,6 and 11). The Cisco kit will 'load-balance' in this scenario, with the client associating to the 'best' AP - and you are correct about them needing the same SSID in order for the clients to roam between them.
Also - you need to ensure that the environent you are surveying is as close as possible to how it will be in operation - i.e. you say it is empty at the moment, but if you fill it full of cardboard or trees or dogfood (whatever) that will impact on the coverage from the APs because of multipath, signal absorbtion etc.
Cisco have a large range of Wireless equipment and sundries, and your one-stop-shop url for all things Cisco and Wirelessy is www.cisco.com/go/aironet.
You may also want to have a look at the Wireless LAN association website at www.wlana.org.
Hope that helps - Best of luck!
Kev
Kev,
Thanks so much for the information! A very concise, and thoroughly complete, answer. I will peruse the links here, and push forward.
Thanks again, hope I can someday return the favor!
Cheers
