Showing results forĀ
Search instead forĀ
Did you mean:Ā
Wireless Authentication Without Controller
Thiago Batista
Level 2
Level 2
Hi, anybody can help with this topic
I can configure the wireless authentication withou controller?
For example - if the user ou PC is member of a specific group in AD, have access to the network
I have a Cisco aironet, and IAS / radius installed
thank“s
Tony Rosolek
Level 4
Level 4
hello, i think this is the guide you are looking for: http://www.cisco.com/en/US/docs/wireless/access_point/12.4_3g_JA/configuration/guide/s43vlan.html
||| Please rate helpful posts. Thanks! |||
