Wireless Authentication
durgesh.p
Community Member
I have to deploy an SSID where clients authenticate against an AD.
I have already configured LDAP on the WLC. When I set the wlc for web auth against LDAP it works, but that is not what I am trying to do, I want wpa2-psk + 802.1x, when I set that config on the WLC, android devices works only if I set "EAP auth method: PEAP" and "phase 2 auth: GTC", but in Windows does not work, only have the options for MSCHAPv2 and EAP-TTLS. Do you know what could be causing this?
0 Replies 0
