Wireless Autonomous AP
S.ashok S
Level 3
Level 3
I have configured one of my 1700 AP in stand alone mode with one SSID but we are able to see two SSIDs.
Ex: I have created "wireless-network" SSID but "wireless-network_1" SSID also broadcasting by the same AP.
Kindly help us to resolve the issie.
Thanks and regards,
Ashok.
5 Replies 5
aleopoldie
Level 7
Level 7
Hello S.ashok,
This is how SSIDs are working on an autonomous AP.
First, you create your SSID :
Example :
conf t
dot11 ssid wireless-network
authentication open
authentication key-management wpa version 2
guest-mode
wpa-psk ascii 0 welcome
And then you link this SSID to the dot11radios 0 and 1 :
conf t
interface dot11Radio 0
encryption mode ciphers aes-ccm
interface dot11Radio 1
Run the command "show run" and check if on your dot1radios you have your SSID "wireless-network_1".
From there, you can go in the dot11radios and put a "no ssid wireless-network_1"
Cheers,
Alex-
Thank you for your reply.
It seams it is already there. Please find radios configuration as below.
interface Dot11Radio0
no ip address
encryption mode ciphers aes-ccm tkip
antenna gain 0
stbc
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
antenna gain 0
peakdetect
dfs band 3 block
stbc
channel dfs
station-role root
bridge-group 1
Thanks and regards,
Ashok
Showing two SSIDs as below
wireless-network
wireless-network 2
But I have configured only one which is first one.
Thanks and regards,
Ashok
I have tried to remove second one from radio but showing "unknown ssid" as it is not appearing.
Thanks and regards,
Ashok.
Hello Ashok,
If you try to disable the SSID from the interface dot11radio 1, the SSID "wireless-network_1" is still broadcasted ?
Alex-
