Wireless Bridge
lenkasurat
Level 3
Level 3
Hello Experts!!
I am having CISCO 1242AG nos.2, I want to configure 5GHZ as bridge mode taking traffic multiple vlans. & 2.4GHZ configured multiple SSID to be utilized by the clients over wireless & fast Ethernet to be configured to switch.
I have tried couple of links & configuration too but not working.
Any configuration sample for the same will be appreciated.
THanks //
Basant Lenka
Rasika Nayanajith
You can refer this post for a wireless bridge configuration(use radio 1 instead of radio 0 since you want 5GHz for bridge config)
http://mrncciew.com/2013/11/09/wireless-bridge-with-eap-fast/.
Then try to configure radio 0 as Root AP for wireless users.
Refer this for wired & wireless users behind a WGB if you interest on that
http://mrncciew.com/2014/01/04/wireless-wired-clients-behind-wgb/
Rasika
**** Pls rate all useful responses ****
Hello Rasika,
Thanks for the response, the commands were same I have applied however, I have to manually enter into the AP through GUI and mapped the ssid to the VLAN. than the radio get up !!
Thanks for the post to making sure always with you expert guys.
Hi ;
Check the following link.
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/69773-vlan-ap-config.html
The only difference is you only need 1 ssid for the point to point link to come up.
