wireless Bridge
filipedorileo
Frequent Visitor
Frequent Visitor
Hi ,
i would like to know if it is possible to have a cisco AP with an antenna that can handle 100Mbps for 10~15 km .
FYI its 3 building im doing redundancy network with wireless connection
Sandeep Choudhary
As per my knowledge.....There is none device that can do it, but you can create a mesh WLAN with (L)AP's that are all connected to eachother!!!!
check the datasheet of 1300 series:
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1300-series/product_data_sheet09186a00802252e1.html
Dont forget to rate helpful posts
ok thank you .
