Wireless Bridges won't associate
arshdeepsingh.grover
Community Member
I have two 1602E configured as wireless bridges.
they connect fine when are close to each other, but when put around 25 meters apart disassociate.
Can someone help me in resolving this issue.
5 Replies 5
Hi @arshdeepsingh.grover
They are standalone or they are on WLC?
 What about their power? As per you description, looks like they have weak signal.
 When they are 25 meters apart, do they
free line of sight or there's some obstacle between them?
-If I helped you somehow, please, rate it as useful.-
These are Standalone APs
The Power is set to max level
and there is a clear line of sight between these APs
What antennas do you have one these 1602e’s? Also what band are you using as the backhaul?
Antenna gain can help depending what you are trying to do here but also the band is where you might want to play with also.
-Scott
DUINBW01#sh run ssid WGB-SSID
Building configuration...
Current configuration:
dot11 ssid WGB-SSID
vlan 10
authentication open
authentication key-management wpa version 2
infrastructure-ssid
wpa-psk ascii 7 1530194D002D781678632163
end
DUINBW01#sh run int do1
Current configuration : 247 bytes
interface Dot11Radio1
no ip address
no ip route-cache
encryption vlan 10 mode ciphers aes-ccm
ssid WGB-SSID
antenna gain 0
peakdetect
dfs band 3 block
stbc
beamform ofdm
channel dfs
station-role root bridge
distance 1
end
DUINBW01#sh run int do0
Current configuration : 204 bytes
interface Dot11Radio0
no ip address
no ip route-cache
ssid WGB-SSID
antenna gain 0
stbc
beamform ofdm
distance 1
end
I'd recommend a site survey just to make sure you don't have a strong interference weakening the signal. If not, I'd say you have some faulty AP in your hands. 25 meters is too close.
There are some commands you can run and share the output. Also, if possible, share show running-config.
  • debug mesh security events enable
  • debug mesh security message enable
  • debug dot1x events enable
  • debug dot1x packet enable
