Wireless Bridges
bob.forster
Level 2
Level 2
350 Bridges, 2 remotes. 1 Remote fine, second remote Re-Associates every half hour or so. Set to only run at 1 or 2 Mbps.
All Bridges are 12.0 Code. Everyhting well within Calculated Parameters.
Alignment test shows: (averages)
Signal Strength 50%, -70dBm
Signal Quality 93%
Is this alignment test reasonable?
Bob
derwin
Level 10
Level 10
Bob I have noticed you have made 3 post all very similar are these all for the same link ?
The above readings are good.
Please try 12.01T1 firmware
Do you see many CRC errors ? What is the distance between the bridges ?
David,
A question.
If I go to a higher gain Omni at the Central Site, will be of any benefit?
(Currently a 5.2bBi Omni)
If it noise or interference related, will pounding thru a stronger signal help any.
The remote has a 13.5dBi Yagi now.
We are going to try a 13.5Yagi to 13.5 Yagi point to point tomorrow.
Bob
Bob,
You can use this spreadsheet to calculate the link budget with different antenna
http://www.cisco.com/warp/public/102/wlan/faq-hardware-us-calc.html
