Wireless Bridges
bob.forster
Level 2
Level 2
David,
You are right, it is the same link.
Have only done two Wireless Bridge installs. This is the first dual Remote.
As I thought, the Alignment test stat are not bad. The link should not be dropping every half an hour unless there is some other problem.
The distance is only 600-700 meters. Direct line of sight.
All Bridges have 12.0 code.
We are going to swap the two remote Bridges and Power Supplies and see if problem follows Wireless Bridge and Power Supply. We are also checking AC Power at bad location.
Just trying to get a feel from someone with more experience. I realize there are many possabilities, but htis is pretty straight forward install! (So I tought)
Bob
tepatel
We need to see the logs on both the bridges when the connectivity is lost.
do they stay associated?
do they re-associate again on their own?
what security protocols running for association etc...
