Wireless bridging
marcelnjkoks
Level 3
Level 3
Which access points can be used as wireless bridges these days?
7 Replies 7
Mark Elsen
 - FYI : https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/16041-bridge-faq.html#q1a
                     However the particular FAQ is from 2009 ...
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Yes, this is not a valid document anymore.
Hence my remark about these days. 😉
 - I was thinking it might be , it would be nice if Cisco could remove FAQ's which are totally outdated.
 M.
Wouldn't that be nice!!
Arshad Safrulla
If you are looking for a point to point bridge my recommendation would be to go with Fluidmesh, If you are looking for point to point bridge using Cisco Wireless AP's then you can use Catalyst 9124, Aironet 1562, Aironet 3802 are some examples, this list may vary on the platform of WLC, code running etc. So take a good look at the release notes before you quote or purchase.
Thanks, we're putting a solution together with 1562's.
Rasika Nayanajith
if you like Autonomous AP using as bridges (Root/Non-Root/WGB), ac wave1 APs (x700 series) are the best. Yes, Cisco has discontinued autonomous code products, still, it works if you are happy with 11ac wave 1.
WGB functionality is there in x800 series products, also mesh option there with WLC based APs
Rasika
*** Pls rate all useful responses ***
