Wireless client IP acquiring delay
komiks
Level 3
Level 3
we are integrating 9800 with ISE for posture check. we observed that when the client provisioning portal pops out because of the url redirection, the delay for the the wireless client to get production IP increases comparing if the url redirection is not working.
When url redirection is not working client acquires IP in less than 20 sec whereas when the redirection is working, i takes more than a minute.
Is there a way to make it faster?
7 Replies 7
@komiks
  The delay is bigger when the communication is working because the traffic must go to ISE in oder to ISE reply with the redirect URL and we need to consider the WLC in between acting as a proxy for this traffic.
When the communication is not working and you are not redirected, the traffic is not going to ISE. Would be like if you fallback from CWA to local redirect and on this case clients move to IP address discovery right the way.
Thanks @Flavio Miranda for the input. So the problem is, comparing to an old the WLC using aireos, it can achieve the faster delay with the url redirection working. I mean with aireos, the client device can get IP as fast as when the redirection is not working on the 9800.
@komiks  Check how guest is configured in both WLC.
There is Local Web auth usually configured in older WLC and there is Central Web Auth used in newer WLC.
LWA the clients first get an IP address and then it is redirected to the portal (internal on the WLC or external) and then the authentication happens. On this mode, the process of getting IP address is way faster as the client need the IP address in order to call the portal.
And then we have CWA, which uses a Radius server for the authentication. On this mode.  the clients does not receive IP address until it is authenticated, just like it happens in any radius process. The client will receive the portal guest url, will authenticate and after that it will receive the IP address.
 Which means, in CWA, will take longer for clients get IP adderss.
We are using CWA on both wlc, on the ise side, we are using the same policies for both wlc. on the process of posturing  on the client, the difference is with 9800 takes longer to get the prod vlan IP.
You can use debug on WLC and ISE to track where the delay comes. Wireshark also helps on this case.
Ultimatelly, you can also open a TAC.
I will send you PM
MHM
Why @MHM Cisco World
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
