Wireless client speed issue download vs upload
Peter Setaffy
Dear all,
Can you please help me with troubleshooting this problem?
I have sometimes clients with HP laptops WIN10 which have problem with upload sppeed on WiFi.
They are connected with full signal near AP on 2.4GHz or 5GHz band and have problem with his upload to network.
Download is about 100Mb/s and upload is 1Mb/s.
I tried use internal and guest SSID and problem was the same.
Also restart NB and problem was the same.
Connect and disconnect client and problem was the same.
We tried go to ohrer location and roam to other AP and problem was the same.
Ethernet ports for this APs dont have any input errors or CRCs.
Client have actual Wireless driver and actual WIN updates.On other clients connected on same AP dont have this problem.Also on my Android phone connected on same AP I didnt have problem wit upload speed.
Its business office enviroment.
WLC C9800-CL with IOS ver 17.3.4c
APs: C9120AXI-E
AP mode: FlexConnect with local switching and local authentification.
Im put here outputs from the problem client from WLC.
Connected on 2.4GHz band:
batc01s#sh wireless client mac-address 6c6a.77dc.9871 detail
Client MAC Address : 6c6a.77dc.9871
Client MAC Type : Universally Administered Address
Client IPv4 Address : 172.16.12.12
Client IPv6 Addresses : fe80::946f:3b2e:11c2:41fc
Client Username : host/NB-NB.abcsk.local
AP MAC Address : 488b.0af6.bc20
AP Name: SK-bata31
AP slot : 0
Client State : Associated
Policy Profile : ACE-SK-Ba-FLEX-Policy-Local
Flex Profile : ACE-SK-BA-FLEX_Prof
Wireless LAN Id: 207
WLAN Profile Name: ACE-SK-BA-ACE
Wireless LAN Network Name (SSID): ACE
BSSID : 488b.0af6.bc20
Connected For : 2321 seconds
Protocol : 802.11ax - 2.4 GHz
Channel : 11
Client IIF-ID : 0xa0000076
Association Id : 6
Authentication Algorithm : Open System
Idle state timeout : N/A
Re-Authentication Timeout : 86400 sec (Remaining time: 84079 sec)
Session Warning Time : Timer not running
Input Policy Name : None
Input Policy State : None
Input Policy Source : None
Output Policy Name : None
Output Policy State : None
Output Policy Source : None
WMM Support : Enabled
U-APSD Support : Enabled
U-APSD value : 0
APSD ACs : BK, BE, VI, VO
Fastlane Support : Disabled
Client Active State : Active
Power Save : OFF
Current Rate : m11 ss1
Mobility:
Move Count : 0
Mobility Role : Local
Mobility Roam Type : None
Mobility Complete Timestamp : 01/24/2022 09:04:14 CET
Client Join Time:
Join Time Of Client : 01/24/2022 09:04:14 CET
Client State Servers : None
Client ACLs : None
Policy Manager State: Run
Last Policy Manager State : IP Learn Complete
Client Entry Create Time : 2356 seconds
Policy Type : WPA2
Encryption Cipher : CCMP (AES)
Authentication Key Management : 802.1x
User Defined (Private) Network : Disabled
User Defined (Private) Network Drop Unicast : Disabled
Encrypted Traffic Analytics : No
Protected Management Frame - 802.11w : No
EAP Type : Not Applicable
VLAN Override after Webauth : No
VLAN : 65
Multicast VLAN : 0
WiFi Direct Capabilities:
WiFi Direct Capable : No
Central NAT : DISABLED
Session Manager:
Point of Attachment : capwap_90000081
IIF ID : 0x90000081
Authorized : TRUE
Session timeout : 86400
Common Session ID: 65F818AC000360378B1D29B5
Acct Session ID : 0x00000000
Auth Method Status List
Method : Dot1x
SM State : AUTHENTICATED
SM Bend State : IDLE
Local Policies:
Service Template : wlan_svc_ACE-SK-Ba-FLEX-Policy-Local (priority 254)
Server Policies:
Absolute-Timer : 86400
VLAN : 65
Resultant Policies:
VLAN Name : SK-BA-Users
VLAN : 65
DNS Snooped IPv4 Addresses : None
DNS Snooped IPv6 Addresses : None
Client Capabilities
CF Pollable : Not implemented
CF Poll Request : Not implemented
Short Preamble : Not implemented
PBCC : Not implemented
Channel Agility : Not implemented
Listen Interval : 0
Fast BSS Transition Details :
Reassociation Timeout : 0
11v BSS Transition : Implemented
11v DMS Capable : No
QoS Map Capable : No
FlexConnect Data Switching : Local
FlexConnect Dhcp Status : Local
FlexConnect Authentication : Local
FlexConnect Central Association : No
Client Statistics:
Number of Bytes Received : 22952800
Number of Bytes Sent : 34804572
Number of Packets Received : 50318
Number of Packets Sent : 105453
Number of Policy Errors : 0
Radio Signal Strength Indicator : -51 dBm
Signal to Noise Ratio : 30 dB
Fabric status : Disabled
Radio Measurement Enabled Capabilities
Capabilities: None
Client Scan Report Time : Timer not running
Client Scan Reports
Assisted Roaming Neighbor List
Nearby AP Statistics:
EoGRE : Pending Classification
Max Client Protocol Capability:
Cellular Capability : N/A
connected on 5GHz band:
AP Name: SK-bata31
AP slot : 1
BSSID : 488b.0af6.bc2f
Connected For : 494 seconds
Protocol : 802.11ax - 5 GHz
Channel : 64
Association Id : 1
Re-Authentication Timeout : 86400 sec (Remaining time: 85906 sec)
U-APSD value : 0
Power Save : OFF
Mobility:
Move Count : 0
Mobility Complete Timestamp : 01/24/2022 10:53:34 CET
Client Join Time:
Join Time Of Client : 01/24/2022 10:53:34 CET
Client ACLs : None
Client Entry Create Time : 494 seconds
Policy Type : WPA2
EAP Type : EAP-TLS
VLAN : 65
Multicast VLAN : 0
Session Manager:
IIF ID : 0x90000081
Authorized : TRUE
Common Session ID: 65F818AC000362918B814593
Method : Dot1x
Local Policies:
Server Policies:
VLAN : 65
Resultant Policies:
VLAN : 65
Client Capabilities
Listen Interval : 0
Client Statistics:
Number of Bytes Received : 7797296
Number of Bytes Sent : 508348445
Number of Packets Received : 25014
Number of Packets Sent : 433941
Radio Signal Strength Indicator : -57 dBm
Signal to Noise Ratio : 40 dB
Capabilities: None
Client Scan Reports
Leo Laohoo
1 Spatial Stream?  20 Mhz channel bond.
The theoretical "best" is about 86 Mbps and a reality speed of around 45 to 60 Mbps.
Please provide the exact model name of the WiFi NIC card and the exact wireless NIC driver is currently running on.
Scott Fella
Just to add. You stated the following:
Do you not think it can be an issue with his laptop?  Use your phone as a hotspot and see if the problem persists. Might have to replace the internal wireless NIC. If you have an external usb wireless adapter, you can test with that and see if it performs better. That will point back to a bad NIC.
-Scott
Peter Setaffy
Guys
Problem resolved.
It was problem with local Hyper-V virtualizations on this workstation.
User had some virtual adapters. After uninstall this Hyper-V feature is connection stable and throughput is about 120/120Mb/s
Peter
