Wireless controller 5508 and AP2802
Khuongnguyen78670
Community Member
Dear Friends
Currently, I have a case Please help me
My laptop uses the ax201 card. the laptop can access the wifi through 802.1x. But when I used it for about 1 hour, then it automatically lost the connection.
But you lsot connection under the same AP? Or when roaming?
For connectivity issues under the same AP I think to remember there are some defects within Cisco COS-AP code that are solved from time to time. Have you tried upgrading Cisco WLC code to latest 8.5 train release?
18 Replies 18
Scott Fella
I would search on the forum or on the internet about AX200/AX201 wireless issues. Some have posted about driver issues so that might be you issue also.
Any ways, to better help, you need to specify the equipment you have and the firmware along with the radius. Also provide the wlan configuration and if any other devices are having the same issue or the issue is specific to this device.  What does the radius logs tell you?
-Scott
Here is log from laptop
Well if you look at the output, you see failed EAP and driver disconnect. The issue is the driver you are running. Like what was mentioned, reach out to Intel and request an updated driver version.
-Scott
Leo Laohoo
On your laptop, post the complete output to the command "netsh wlan show drivers".
Scott Fella
A good netsh command is netsh show wlan reports
https://www.howtogeek.com/367100/how-to-generate-a-wifi-history-or-wlan-report-in-windows-10/amp/
-Scott
JPavonM
I've managed to check some issues with AX2xx wNIC from Intel, and most of them are solved upgrading drivers.
The latest one Intel is fixing is when the adapter roam from one AP to another and the SSID is configured to use 802.1X. In this scenario you could end up losing IP address but associated, and then after the next L3 re-auth period the connectivity returns, or you manually force reconnection.
Check this thread on Intel communities, the moderators mentioned there should be a new driver released in the next week from Intel (maybe a month later by OEMs) that fixes this behaviour:
https://community.intel.com/t5/Wireless/Intel-WiFi6-AX201-160Mhz-L3-Issues-with-RADIUS-Authentication/td-p/1324596
-Jesus
*** Please rate helpful responses ***
I already do step by step and update the firmware card. but still not working. Do you have any update
the same AP. currently Wireless controller and Ap 2800 is only support AC. but i have another laptop use the ax200 was normal
Well, you are now isolating the issue.  The key is figuring out what is working and what is not.  If its a single device that is giving you issues, then it would seem to me that the issue is that device.  AX200 and AX201 uses the same driver, but if you don't see issues with the AX200, but with the AX201 and are using the same driver, then it's probably a bug with the AX201.
The netsh wlan reports will provide you with good information so you can see how long that machine was connected and when issues started.  Might even show some roaming or scanning to another SSID which might also be the issue.
-Scott
Rich R
And if you read the Intel link @JPavonM provided you'll see the latest driver has not been released yet but is available on request from Intel if you reply on the forum asking for it.  So I would start off by getting that latest driver from Intel before you do any more testing.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Thanks Let me update the latest driver.
Please read @Scott Fella and @Rich R responses very carefully.
How are you planning to accomplish this when the latest fixed version is only "by request"?
