Wireless Clients are unable to obtain DHCP address
Mr.Mayhem
Am doing this in packet tracer. I am able to connect to my the AP's are getting an address through DHCP but my wireless clients are not and I am not able to figure out why. I have attached my packet tracer file. Any help would be very much appreciated.
Sandeep Choudhary
how is setup look like ? could you please explain about it ?
a Wireless LAN Controller located on a remote network. This network includes two
WLANs: Admin and Employee.
 3 VLANs
• All DHCP will be performed by R1; all hosts (PCs and APs) must use DHCP
• A loopback on R1  to simulate the Internet
Building configuration...
Current configuration : 1848 bytes
version 15.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
service password-encryption
hostname R1
enable secret 5 $1$mERr$9cTjUIEqNGurQiFU.ZeCi1
ip dhcp excluded-address 192.168.99.1 192.168.99.10
ip dhcp pool EMPLOYEES
network 192.168.10.0 255.255.255.224
default-router 192.168.10.1
option 43 ip 192.168.10.2
ip dhcp pool ADMIN
network 192.168.20.0 255.255.255.224
default-router 192.168.20.1
ip dhcp pool MANAGEMENT
network 192.168.99.0 255.255.255.224
default-router 192.168.99.1
ip cef
no ipv6 cef
no ip domain-lookup
spanning-tree mode pvst
interface Loopback0
ip address 9.3.3.1 255.255.255.252
interface Loopback1
ip address 1.1.1.1 255.255.255.252
interface Loopback2
ip address 2.2.2.2 255.255.255.252
interface GigabitEthernet0/0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0/0.20
description ADMIN
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.224
interface GigabitEthernet0/0/0.30
description EMPLOYEES
encapsulation dot1Q 30
ip address 192.168.30.1 255.255.255.224
interface GigabitEthernet0/0/0.99
description MANAGEMENT
encapsulation dot1Q 99 native
ip address 192.168.99.1 255.255.255.224
interface GigabitEthernet0/0/1
ip address 192.168.10.1 255.255.255.224
duplex auto
speed auto
interface GigabitEthernet0/0/2
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.10.2
ip flow-export version 9
line con 0
password 7 0822455D0A16
login
line aux 0
line vty 0 4
login
line vty 5 15
login
end
Current configuration : 2373 bytes
version 16.3.2
hostname S1
no ip cef
no ipv6 cef
no ip domain-lookup
interface GigabitEthernet1/0/1
switchport trunk native vlan 99
switchport mode trunk
switchport nonegotiate
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
switchport access vlan 99
switchport mode access
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface Vlan1
no ip address
shutdown
interface Vlan20
mac-address 0002.17d0.2e01
ip address 192.168.20.2 255.255.255.224
ip helper-address 192.168.20.1
interface Vlan30
mac-address 0002.17d0.2e02
ip address 192.168.30.2 255.255.255.224
ip helper-address 192.168.30.1
interface Vlan99
mac-address 0002.17d0.2e03
ip address 192.168.99.2 255.255.255.224
ip helper-address 192.168.99.1
ip default-gateway 192.168.99.1
ip classless
line con 0
login
line aux 0
line vty 0 4
login
line vty 5 15
login
end
Did you configure the DHCP for the dynamic interfaces at your WLANs?
"A dynamic interface is used to connect the controller to a VLAN on the wired network."
Inside the dynamic interface you will say which DHCP serve will provide the IPs for your WLAN.
PACKET 7.2
Select the option DHCP, selects the interface and configure the right DHCP for each WLAN
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
I ended up getting it. I did not have my trunking set up properly also had an incorrect ip on my router. Thanks for looking at it.
